EZ Mold build for a OO. http://www-.luthiersforum.com/forum/viewtopic.php?f=10117&t=45026 |
Author: | Glenn_Aycock [ Tue May 19, 2015 8:59 pm ] |
Post subject: | Re: EZ Mold build for a OO. |
Rather than gluing up the layers and cutting out each half (lots of sanding), if you use dowels or some other means of registering/aligning the layers, once you cut/sand/perfect the first one, you can rough cut the others on the bandsaw and use the first one as a template to finish the rest with a router and pilot bearing bit. Very little additional sanding needed. Then glue them together. |
Author: | Linus [ Fri Jun 05, 2015 8:06 am ] |
The router method would work well too. I have an random orbital spindle sander connected to dust collection. I'm pretty good with a band saw so the sanding doesn't take long at all. Lots of ways to get from point A to point B. That one of the reasons I like this forum so much. I get to see lots of different ways to accomplish the same task and decide which works best for me. |
Author: | Glenn_Aycock [ Fri Jun 05, 2015 10:41 am ] |
Agreed. I just try to avoid sanding (and routing) MDF as much as possible. Even with a dust collector, that stuff goes everywhere, and it dulls blades quickly too. Sent from my iPhone using Tapatalk |
